Unconfigures the source VLAN to use as the source IP address in the BOOTPrelay packet.
bootprelay | Specifies BOOTPrelay agent information option. |
dhcp-agent | Specifies DHCP agent. |
source-vlan | Specifies unconfiguring the source loopback VLAN to use as the source IP address in the giaddr field when BOOTPrelay is used for anycast VLAN. |
vr | Specifies unconfiguring the VLAN on the specific virtual router ID. |
vrid | Specifies the virtual router ID. |
If you do not specify a VR, the unconfiguring occurs on VR-Default.
To view the selected source VLAN, use the command show bootprelay configuration {ipv4 | ipv6} {{vlan vlan_name } | {vr vr_name}} .
The following example unconfigures the VLAN to use as the source IP address in the BOOTPrelay packet on vr "vr1":
# unconfigure bootprelay dhcp-agent source-vlan vr vr1
This command was first available in ExtremeXOS 30.7.
